VanIsleDSM
I've just converted my bench grinder to have LED work lights, originally they were 10watt incandescent bulbs running off 12VAC, if you'd like to see more of that look here:
http://www.candlepowerforums.com/vb/showthread.php?p=2417478#post2417478
I used a full wave rectifier and an LM317 with a 1.2ohm resistor, which on straight DC current would be 1.25/1.2 = 1042mA.
Because a full wave rectifier doesn't put out straight DC current, with my DMM I actually only measured 314mA through the LEDs.. I'm not sure how exactly the DMM averages the 1042mA spikes to reach 314mA.. but I know there are true RMS meters.. and I know my is not one of those fancy ones.. so I don't exactly know how it's getting that figure.
Adding a 920uF smoothing cap brought the DMM reading up to 610mA.. I tried a 4700uF too (which would have been too big to fit) and it reached just over 900mA..
Now I also have another project going on some pond lighting.. the original NOMA power supply is again.. 12VAC, I used a full bridge rectifier but no smoothing cap this time.. using LM317s with 1.2ohm resistors I get 680mA on the DMM.. I suppose it must have more internal capacitance.. but then you'd think adding more load would decrease the current reading through each series set of LEDs.. but it doesn't.
And something else I can't understand.. for the pond I also have some standard LEDs wired in series with resistors.. but in this case.. unlike hi power LEDs with the constant current LM317 drivers.. I get results just like as if I was using real DC current... 9.5VCD on the pond I'm using 33ohms of resistance for 2 ~3.5v 100mA LEDs in series.. getting about 96-97mA on the DMM.. using straight 9.5VDC from a new 9v battery gives me virtually the same reading on the DMM.. shouldn't the rectified signal provide less power?
..while typing that I just had a revelation, I suppose the 9.5v I read on the DMM is obviously also an average, and that's why I get an average of about the same current too... I know LEDs can usually handle quite a bit of ripple current, but it can create thermal problems if there's too much.. hopefully I'll be fine.. all the LEDs are heatsinked very well.
One more confusing thing.. on the pond the output was ~12VAC under load, but when rectified drops to ~9.5VDC under load.. while my grinder was about 10VAC and went up to ~12VCD when rectified.. I thought the voltage went up when rectified.. but the NOMA power supply went down? Some internal reason I suppose.
Anyway.. just thought I'd start this discussion to get more insight into all of this...
