My problem with 623 bulbs may also be the voltage I selected. Perhaps LuxLuthor might comment on this. I selected 16.5 volts. That may be a bit much. This bulb seems to have a somewhat soft failure zone according to Lux's tests, but I note that he chose lower voltages for his lifetime testing. So I have a combination of a high voltage, short 100 mS quick soft start, and very low impedance lithium-iron nano-phosphate batteries that put a lot of stress on the bulb, apparently.
During development some folks were not happy with the long natural soft start that my algorithm has - as Jim mentions it is up to slightly over a second, depending on the battery vs bulb voltages. So I added code to move in larger steps when the error was large. It reverts to small steps when the error is lower, that is when it approaches the correct output voltage. This is an easily changed compile-time parameter.
I am considering doing two things to reduce the problem I had with the 623. One is to change to 16.0 volts default max on this bulb. The other is to lengthen the default fast soft start to 200 milliseconds.
Comments??
Yes on both strategies. Personally, I would never push the extreme edge of my flash points for any regulated setting. For the 623, I would set regulation at 15.3V and see how long it ran, and how the bulb output quality held up. If it seemed to be more than 6-8 hours, then I would go up to 15.5 to 15.8V and watch it again.
I'm sure that 16.5V is the primary source of your failure. I also think 100ms is too quick, especially for higher Watt bulbs. Although AWR's Hotdriver seems instantaneous (so is likely 100-200ms). I would have to go back over his threads and notes to find out what he had, but his mechanism of soft starting and regulation is totally different.
Take a look at this new topic where I posted download links for the three Excel files that can also give you some idea of predictive work that AWR and I worked on after he left.
KiwiMark, there is no harmful downside to making the softstart longer. I think people raised an issue early on not wanting it to be too slow so it was significantly noticeable. Longer time of softstart represents safer cushion protection from surge of current rushing into the cold filament...but at some point, the delay becomes cosmetically irritating...like...."Turn On ALREADY!!!" So Alan picked 100ms, but I think that is a bit too fast for more demanding bulbs that need more current like the 100W 64623. As a comparison, I think AW's soft starter multi-level driver/switches are around 1,200-1500ms just eyeballing some I have.
