5761 vs 1164 vs 1185?
That's the choice I'm having trouble with right now.
One of the regulators will be a '623, for sure, with whatever parameters you've found best.
One will be for the Battle Lantern, and I'll wait for that one.
But one will be a low-power hotwire, using one of the 3 listed above. I currently have all of them in a variety of configurations, ranging from AW's soft-starters to AWR's regulated switch.
I like them all, but tend to grab the 1164s more often than the others.
How about other user's opinions. Which of these would benefit most from the regulation offered by Alan's Sled? I'll probably use 26650 A123s most often.
Really an excellent question, donn_
I also have all three:
5761 in 2D fed by KD D Li-Ion
1164 in bored 2D fed by 8xAA NiMH
1185 in 3D fed by 9xAA NiMH or 3x KD D Li-Ion
They are all nice. I like the shorter lights at this power level, so the 1185 drops out of the competition.
Between the 5761 and 1164 it is a harder choice. The KD Li-Ion cells have a lot more energy, about 30 watt hours compared to 20 watt hours for 8xAA Eneloops. So the 5761 runtime is a lot longer. The really clean 1164 glass envelope has a slightly cleaner pattern, but the difference is small. Reflectors matter more and I don't have a lot to choose from there.
At the end of the day I think the 5761 has a slight edge for me due to the longer runtime, lack of need to bore the light, lower cost bulbs and not needing an expensive cell carrier. With the regulator and the lower power settings we have a really practical incan here. On full power it should run more than 45 minutes at about 1400 lumens, and at less than full intensity it can go for several to many hours.
Note that the A123's are a bit low in voltage with 2 of them, so that pushes it up to 3 cells. Really the A123's are better suited to high current than these lights. Three of them is about 23 watt hours, whereas 2 of the KD D Lions are about 32 watt hours.
But any of them would be excellent choices.
