DIY Aspheric Throwers: Observations/experiments/feedback
gcbryan
Seattle,WA
I set out to find out for myself more about aspheric throwers and ordered parts for a DIY experiment to see how flashlights with 28mm, 35mm, and 45mm aspherics would compare.
I don't have any pictures and am just posting my thoughts and some things I learned as I was looking for this kind of post before I started all of this.
The idea was to find lights with head diameters of approximately 50mm, 40mm and 30mm. I used an Ultrafire P60 host (6P clone), an Aurora 40mm head light and the Ultrafire HS-802 (50mm head) super thrower.
All initially came with reflectors and all used XR-E R2 emitters. They all were powered by (1) 18650.
The optics were the 28mm glass optic from DX, the 42 mm glass optic from KD (the best), and a 50mm glass optic from DX.
I ground the lip down on the 42mm and the 50mm to 35mm and 45mm respectively. The 28mm needed no grinding.
As far a optic quality subjectively measured by how well the emitter could be focused the ranking is KD 42mm (best), DX 50mm OK, and DX 28mm (acceptable but not great). I have a plastic 28mm optic from one of the flood-to-throw lights that is better than the glass version however the plastic optic has a shorter focal length and isn't usable as a direct replacement for the front lens.
The 28 mm drops directly into a 6P clone, the 42 mm replaces the front glass but needs to be ground down first.
The 50mm needs to be ground down to 45mm to replace the front glass but it's not in focus but this is as far as I've gone. It needs to be ground down another couple of mm and then an optic mount needs to be fashioned further down the head.
This is the only inconclusive aspect (as far as direct observations) in this experiment. I did indirectly test it though.
I've found the Aurora (which comes with a forward clicky) to be the best option for a small DIY aspheric based thrower. All of these are single mode by the way. The HS-802 came with a two mode resistor based reverse clicky but that requires 3 full clicks to turn off (annoying) so I replaced that.
Actually, I replaced that with a forward clicky (all of these lights have those now).
The Uniquefire HS-802 with the reflector throws further than any of them. I tried the ground down 50mm (now 45mm) and although it wasn't in focus it came close when I reversed the optic with the curved side facing the emitter. The results weren't impressive however (not bright enough).
I don't plan on permanently modifying this light (which would be required) with an aspheric but I do plan to continue grinding until I can test the optic curved side outward in a temporary mount just to finish these experiments.
I'm impressed by the reflector's ability to throw in this one though and will keep this as my reflectored thrower and the Aurora with the 35mm optic as my smaller aspheric thrower.
I've disassembled the 28mm aspheric flashlight and will use that for more dive light experiments.
The reflector was removed and therefore not used in the Aurora aspheric mod.
So, I learned that you have to guess and just order a few different aspherics since at least at DX and KD you don't have much info (focal length) to go on. Generally you just have diameter. You generally can't find anything that is an exact fit. With a (borrowed) bench mounted belt sander grinding glass isn't that hard.
Optical quality varies greatly and that's just a gamble as well.
With the Aurora since I could take out the reflector I did no painting. I left the silver ring around the emitter alone as well partially since it wasn't easy to get down there and partially since the optical quality of the 42mm KD lens was good enough that I could live with the untouched results.
Ultimately, I was really impressed by the HS-802. It throws a long way and put a good circle of light on the subject around the tight center hotspot.
It's nice to have two types of throwers though I've decided. I like the aspheric for situations where you want a spotlight on the subject but don't want to light up anything else.
I like the reflectored thrower as it lights up a larger subject matter although the actually hotspot is as tight as the emitter image with an aspheric.
One more point...drop-ins aren't the best for DIY aspheric throwers only because you can't fine tune the focus adjustment of the emitter image. You need the reflector (painted out) to use as a spacer between the optic and the emitter and therefore it's fixed.
With a light that has a fixed emitter you can generally fine tune the focus by either screwing/unscrewing the head or screwing/unscrewing the emitter pill.
I've tried to just throw out a few practical things I've found out during these experiments. There are no beam shots so it won't be interesting/entertaining for some but hopefully it might be helpful for any of you interested in a DIY thrower project.
GC,
Thanks for your work, all "good to know" stuff. BTW, KD has its 28 mm aspheric back in stock [going to order a couple shortly].
Following what you've done, I'm looking at some TIR optics to replace P60/D26 and D36 reflector in drop-ins. Plenty of choices just need the $$$ and time to do the work.... I want to see if I can build a "T60" drop-in ala the Malkoff M60 and a D36 sized variation. Only time and $$$ will tell.
GC,
The only thing I can add regarding TIR type optics is that DX has some that snap on XR-E emitters (don't even need glue). They are called "diffusers" I believe in the DX description. You get a bag of 5 for $5 or something like that.
I've used them in a couple of lights. Just take the reflector off and snap them in place. The result is similar (to that of the reflector) except that they have a small collimation lens over the emitter so that is directed back into the hotspot and therefore the spill is not as intense and the hotspot is more so.
The noticeable result is that the usual hard edge going from the outer edge of the spill to complete darkness isn't there (or is greatly reduced).
So you don't have this big halo moving around as you shine your light.
I've never played with any of the Ledil (sp?) TIR optics but would like to. The DX version was just cheaper and easier to get.
Bryan,
I didn't mean to hijack your thread cos I AM interested in aspherics as well as TIR optics.
I don't know if you've ever looked at the Edmunds Optics site but they do list several size aspherics that would fit common P6 type lights.
http://digitalcatalog.edmundoptics....source=google&utm_medium=ppc&utm_campaign=us#
Look on the bottom of page 67.
Not cheap but probably MUCH better quality than DX or KD
As to TIR optics... my plan is to order some Ledil & Dialight optics from Digikey. I found Carclo TIRs at Future Electronics and I'm still hunting for a distributor for Khatod TIRs....
Another hijacker here as I'm really interesting since some weeks in aspherics lens and TIR optics as well :devil:
Yesterday I prepared a cart full of all TIR optics avalaible in KD but the annoying thing is the outer diameter of those optics and lack of description for some of them.
Bryan,
Thank you for the link.
Tally,
Both KD & DX have little if any data on the TIR optics so its impossible to tell what will fit what emitter....
Both DigiKey and Future Electronics stock a good selection of TIR optics. You can actually find data as to what optic fits a Cree XR or XE emitter!
DigiKey stocks Ledil optics plus a few from Dialight that fit Cree emitters.
go to the DigiKey site and use search for "LED lenses"
Future Elec. stocks Carclo, Khatod, Dialight, and Fraen. I'm still exploring the Future site for suitable optics that you don't have to buy a whole tray or box full to get ONE optic...
From the Future Elec home page click on "lighting solutions" page and find the "single LED optics".
Future Elec appears to only stock Luxeon / Rebel emitter specified TIRs....
Tally,
Don't worry, yesterday I was looking for Cree warm white LEDs on some resellers website and saw the TIR optics brands you mentionned:
http://www.anglia-lighting.com/products/optics/index.asp?opticsFor=CREE
On KD, I was looking for the models that look the same, the white ones on the first page when you do a search on KD with "lens Reflector for Lumileds"
...etc.
My KD cart is only to keep a track of their products I am interested with...I will probably delete some or a lot of them before my next real order.
Tally,
Nice link to the Anglia site. The Polymer Optics is interesting stuff. The hex form makes really compact multi-emitter heads possible. Wonder how many you could pack into a M@G head???
Bryan,
Have you checked out the Surplus Shed site? Lots of inexpensive aspherics.
http://www.surplusshed.com/pages/category/lenses_1.html
I found nearly 20 asherics and spherical lenses, a few may be near drop-ins for some common lights.
http://www.surplusshed.com/pages/item/l10085.html
This might fit the SkyRay/UF or similar sized lights.
Others would probably fit some of the less popular DX/KD lights w/ 40mm dia heads
http://www.surplusshed.com/pages/item/l10171.html
And some like this:
http://www.surplusshed.com/pages/item/l10226.html
or this:
http://www.surplusshed.com/pages/item/l3786.html
might work in the HS-802 or the WF400/500/600 "thrower" lights.
Guess its time to put in orders at DX/KD and the Shed....
