DIY Cree R5 focusable U/W light
Well that is so simple and effective... Hats of to you sir.
Well done, just goes to show these things dont need to be complicated.. :twothumbs
Whats lens did you use?
Wow.
wll done, very well done.
(p.s. that tall thin doorway is very reminicient of Nihon)
nice system. does it stay in the same focus when you shake it around?
which lens are you using?
where would you get such magnet?
'no chromatic aberrations' is not correct though. You won't see it due to the intense light. chromatic aberrations are always present with a single lens as this is an effect which is caused by the wavelength-dependend refractive index of the material.
Johan
My respect! Mac Guyver could not done better! I almost wait for your newest inventions, but this is by far your best one.
The only problem I see: does it mislead your compass?
I wonder if Michael (mb sub) used the same princible. But by fixing an aspheric to the threaded part that is turned to adjust the focus..
I dont use the same principle!
Its a simple way to adjust the focus, but with a disadvantage:
with the magnetic system you will lost the regulated position by a hard hit.
Michael
Yeah, but then he'll just slide the outer ring down and re-link the magnet on the inner lens. It's magnetic, after all.
Could be the only focusable system that can be fixed by end user with no tools while underwater.
Excellent project...the most interesting yet!
People manage to use scooters with a compass on the other wrist...I don't see this as being a problem.
Hannachan, can you describe the parts, where you got them, and how you made it all fit together so well?
thank you for a lot of responses.
id like to answer the questions which i can answer now.
ill report the details of making later.
*magnet
it is 'Super Strong Rare-Earth RE Magnets' from Dx.
http://www.dealextreme.com/details.dx/sku.13516
or
http://www.dealextreme.com/details.dx/sku.5962
i used 2(ply)x4(place) pieces for the internal ring and 3x4 for the external.
total 20 pieces magnets were used.
*lens
i have used a good many lenses got from the junk camera or SLR lens
as a DIY U/W macro lens.
the lens is one of them. achromatic & about 20mm focus length.
i tested other achromatic lenses for focusable light, the results were very good,
they showed REALLY NO chromatic aberration.
the spot quality is much better than aspheric lens from DX.
*influence on compass
ive first recognized this possible problem when pointed out. thank you.
so i bought a cheap compass today and checked the influence of the
magnets of this light on it.
The light approaching to the compass about 15-20cm distance moves the
magnetized pointer of the compass.
although there may be some solutions for this problem, change magnets arrangement,
number of them, magnet shield etc. , i think the basic solution is difficult.
when checking the compass, the light must be apart 20cm over from the compass.
thank you again.
Thanks for the answers. I would have thought you would have needed more of those magnets.
I use about 7 of the 8mm ones in my reed switches.
How stable is the lens? Will a good shake dislodge it from the outer rings magnetic grip or will it simple move away then be attracted back?
Very cool indeed.
wrt to jarring, couldn't internal threading be used to stablize the lense?
Matching external threads might add more fine grain control too.
The design would allow for any number of LEDs... sst-90 anyone?
