Do red LEDs use less power?
Will_
Arizona
I heard that the red ones use a lot less battery than white ones. If this is true, then red LEDs are a lot more efficent than white ones with a red filter.
TorchMan
Texas
Yes, it's my understanding that red LEDs use less power than white, and are more efficient than a white with red filter.
Lynx_Arc
Tulsa,OK
red leds are driven at about the same current and similar brightness I think but the considerably lower Vf makes for a lot less power use.... probably about 1/3 less or so.
jtr1962
Flushing, NY
Reds are certainly more efficient than whites with a red filter, probably by a factor a three or four. However, in terms of overall efficiency emitting visible light whites are actually better, although not by much. I recently measured some 9000 mcd reds at roughly 40 lm/W. The same company now has 11,000 mcd with a similar beam angle which should manage in the high 40s. The better 5mm whites are in the 60 to 75 lm/W range according to my tests. However, that doesn't tell the whole story. In terms of converting energy to light the best whites are about 20% efficient while the best reds are probably around 35% or so. The lumens per watt are less simply because our eyes are less sensitive to narrowband red light than to white.
Yes, at 20 mA drive current reds use less because their Vf is in the 1.9 to 2.1 volt area instead of the 3.2 to 3.6V typical of whites.
scaredofthedark
TX
narrow band red light??? what does that mean?
i thought red has the longest wavelengths in the visible spectrum
cratz2
Central IN
I think by narrow band, he is referring to the fact that it isn't a wide range such as white but only a limited range of color.
I tell you, I have a Garrity Stainless pen light with about a 7,000 MCD (might be a 9,000) LED into that I put two, we'll say, 80% fresh NiMH cells into and it's still as bright today as when I put it together a year ago... Granted, I don't use it every day, but it seems to last and last and last.
PhotonWrangler
In a handbasket
Narrowband = monochromatic. For instance, one of the reasons why LED traffic lights stand out among the visual clutter of a busy intersection is that their color is fairly "pure" or monochromatic, something that we usually don't see in nature. An incandescent red traffic light doesn't stand out as much, partly because the "red" actually contains many wavelengths of reddish-orangeish colors.
When you look at a spec sheet for an LED (other than white), you'll see a dominant wavelength specified. While the LED may put out a few other wavelengths very close to the dominant one, they're greatly attenuated. LEDs are extremely efficient compared to incandescents in producing a particular color because of this.
