Does anybody know what's inside a 3-led headlamp?
corniche
Does anybody know what\'s inside a 3-led headlamp?
I mean the Petzl Tikka-like headlamps that use 3 AAA batteries. I'm really curious of what's inside. Is it just a resistor in serie with the leds or do they use some real led driver IC's
Re: Does anybody know what\'s inside a 3-led headlamp?
I guess nobody does.
If it's a 3AAA light, it is more likely a resistored light. If you have one on hand you can measure the REVERSE resistance. If it's a resistored light, you will get "over range", but if it actually has some IC inside, you will get a significant leak current. Old mechanical multimeter will do better in this kind of tests.
My 'normal' Tikka and Zipka (and their Asian copies) do not have even a resistor, they rely solely on the LED's and the AAA cells internal resistance.
I used to use a Zipka with almost dead cells for reading.
Edit: Sorry I forgot that my Tikka is a 'modded' one for use with almost empty cells. Normal Tikka has a 3.3Ohm resistor.
"Does anybody know what's inside a 3-led headlamp?"
Thats an easy one!
3-leds!!!! /ubbthreads/images/graemlins/icon15.gif /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/grin.gif
Sorry couldn't resist, no answer here!
Alex
It depends on the headlamp.
Not sure what's in a Tikka, but I have a couple of Zipka+s, and they have multiple light levels/flash accessible via a single button (not a switch). This means there is driver circuitry in there.
Yes, thats why I wrote the 'normal' version. That should mean the Zipka and Tikka without 'plus'.
Sorry for not expresing myself clearly enough. The plus versions have a PWM.
Corniche,
There is a reisitor inside the Tikka/Zipka models that will drop the voltage to 3.6V
Sorry for the delay in answering your question, my access has been down for a couple of days. /ubbthreads/images/graemlins/tongue.gif
