Does anyone know the size of the Muyshondt AEON MK3's pocket clip screw?
bobb
USA
Does anyone know the size of the Muyshondt AEON MK3's pocket clip screw? The screw hole is broken, so I would like to drill a screw hole that is one size larger than that screw.
Each dimension is like this. The width of the screw head was 3.7cm to 3.65cm
Most likely it is screw number 1, but as for the thread pitch, further research is needed
If you've recently moved to the United States, be prepared to encounter the imperial system of measurement more and more often
