Does the flashlight fit in your mouth?
Hell, beats holding this one in your mouth
Mind you, unless you are Steven Tyler, you prolly couldn't anyway..
I still keep The Original KD (version 1) buckle light in my pocket because its tail is shaped just like a whistle.😗
+1
I carry the Quark AA regular UI in the belt holster.
Yes I can clip it to a visor or cap, but never wear those.
Solution: I keep the black rubber Quark Finger Grip Accessory on the rear tail switch. It goes into the holster just fine (tail up).
It is a perfect tooth cushion for my front teeth when the need arises!! {You can bite the covered switch, or the rubber loop meant for the finger, but the later will make for a bouncy beam}
It also serves nicely for a secure hand grip as intended.
I will probably buy the Quark Prizm as well, but I will not have it and the headband handy unless I'm planning on hands free use like night time metal detecting or some planned project.
So you Quark users out there, pull that finger grip thing out of the packing box, and keep it on your light. Your teeth will thank you later. 😀
+1
I actually cut the finger loop part off as I don't use it but left the rubber ring on the light for the same reason! Much easier on the teeth and you can hold it a little more tightly. 🙂
I asked Santa for a Zebralight because I wanted an EDC light that I could either wear with a headband or clip to my shirt pocket for hands free work. Santa came thru! Fenix MC-10 looks interesting as well for this purpose, although not quite as small as the Zebralight.
I'd like to know if anyone can suggest alternative headband or clips for H501W and where I can buy them. I'd like to be able to snap it on and off the clip vice using the Zebralight supplied band and clip..
Guys, I think we should take up a collection for our friends here that have no chiclets left and have Gizmo or someone make them some in Titanium...what say ye?
I like those clips also. Just clip it to my tongue and it won't fall out of my mouth :green:
Jim
I've noticed the QMini123 to be really easy to mouth hold, unlike other CR123 lights. Being light weight helps, too.
Geoff
Only happened one time, but had to hold my Arc-P AAA btn my teeth in order to use a service station restroom when the light had burned out. I just love it when you have a light handy when it is truely needed !
I still have an Arc LS ( LSHF-P ). Sold the LS I had along with the AA adaptor sleeve with switch. They are very good EDC lights.
When I carry mine, I forget it is there unless I need it. Never had to mouth it. But it could easily be done in a pinch.
