As title says, I have a doll house lighting project going. Don't have all the details yet, but probably 9-12 5mm white leds, 14,000 mcd from DX. I used the led array tool here:http://led.linear1.org/led.wiz
So, rather than a constant current circuit, I want to power this from a wall wart power supply and resistors. I feel it will be "good enough."
My concern is what will be the effect of a switch mode power supply vs a simple transformer? I am considering this power supply here:
http://www.allelectronics.com/make-a-store/item/PS-1236/12VDC-300MA-SWITCHING-POWER-SUPPLY/-/1.html
A switch mode power supply varies current to attempt to keep voltage at the same level? Or varies voltage to keep current the same under a load? According to the tool I will only have a draw of around 80mA.
Thanks.
Thanks.
