Re: Help with my first hotwire. Using FiveMegas Throwmaster
Man, I don't know how I ever got along with lesser flashlights. The MAG85 is just SOOO friggin bright, but with such a useful beam and usable (~40min on 9NiMh AA) runtime. Plus it will project enough heat and IR to light paper on fire and impress the non-flashaholics, but is not so hot as to be dangerous like a mag623.
The KD bulb adapter is great.
The KD glass lenses also work fine. I crack lenses from time to time so I gave up on the nicer coated ones. Your light may not see the moderately hard use of mine though in which case the AR coated lenses would be worth the $5 as they DO result in better light transmission.
Also, the KD gold plated tail spring is well worth the $5
For sure get the FM 9xAA batteryholder....it is top notch. It is so nice to just plug my charger into FM battery holder and charge away.
Agreed. FM's batteryholders are a friggin work of industrial art and are well worth the $40.
I don't use the pack charging feature myself as I prefer to charge my NiMh's in my LaCrosse charger. You may or may not want to charge as a pack. It is certainly convenient, but it is not necessary and one can save a little $ by not doing so. I find it is easier to keep a backup set of batteries than to charge the whole pack.
Also, FM's metal reflectors work much better with 1185 bulbs than the KD reflectors. The KD reflectors are good quality and Kai is a great guy, but the two designs have slightly different shapes and the FM design works much better in this app.
If your allowance is able to handle it, get AW's D size incan switch. It will give you 3 levels of light and it will make your light way, way better than you thought it ever could.
I will not build another hotwire without one, particularly if you really want to make a sweet little light, and a little light you can really use in different conditions/situations. Low, med and hi are just to nice to have on a light this powerful. Really it mostly helps out on the "poof" problem with overdriving these bulbs.
I really wanted one of these until I found that you lose the momentary on feature. Yes, I know how janky the mag switch system is internally, but it hasn't failed me yet, and I really like having momentary on. If that isn't important to you though, then the multi-level feature would be very nice.
Hope that helps,
-Pete
