Yup. Same voltage requirements as white/blue/green/uv highpower leds. The board has a + marked on one side, or look at how the led is mounted (I belive the lead to the large cup is neg). I just twisted my head off with my hands. I think others have said that theirs have had locktite on them, then use a strap wrench. UV led, well the lower the wavelength, the better. You'll have less visable purple light, but more of the UV that makes stuff glow good. 400-395nm is the standard UV offered, but you can get 385,370nm leds but those costs a lot more, but are really cool.
Keep in mind UV leds don't last as long as normal ones, and the dorcy overdrives the white led in there anyways, but you'll be using this to inspect things, not light up your tent all night so no real worries there.
