Robocop
Mammoth Killer
I know the dorcy AAA board is a simple step up circuit and I am playing around with the idea of attatching 2 5mm LEDs to this board.I am attempting to adapt a 2 AA light to use this board and will run the 2 LEDs from 2 AA cells.This will be 3 volts in and I know the circuit will boost the output but will it be enough to run two LEDs?If so would it be better to wire in series or parallel for ultimate brightness?I have adapted this board to a host using one AA cell with good results.Also is a step up circuit set to a certain level?If using this board for example and supply 1.5 volts will it be the same output as if 3 volts were supplied?
The LEDs are both from dorcy AAA boards and I am simply using one board for two identical Leds.
