Wildcat Enlightened Joined Nov 4, 2003 Messages 281 Location Kingwood, Texas, USA Apr 14, 2004 #1 Once the voltage drops to below the regulated amount, does the light go to Direct Drive or does it go out till you put in fresh cells? Thanks
gadget_lover Flashaholic Joined Oct 7, 2003 Messages 7,148 Location Near Silicon Valley (too near) Apr 14, 2004 #2 I'm pretty sure it's direct drive. I tested mine on a bench supply last month when assembling a light, and I would have noticed if it did not light up until Vf was exceeded. There is a lower limit in the specs somewhere. Daniel
McGizmo Flashaholic Joined May 1, 2002 Messages 17,304 Location Maui Apr 14, 2004 #3 It shifts nicely into direct drive. I have been using this feature in my two stage switch mods where a resistor will drop the Vin below Vf. Depending on your power supply however, it may be that when your voltage drops below Vf, your batteries are well depleted and not much power is left.
Wildcat Enlightened Joined Nov 4, 2003 Messages 281 Location Kingwood, Texas, USA Apr 14, 2004 #4 I'm wanting to run a TVIK Lux III on a Hotlips using 2 Pila 150's. I know that the fresh cells push my Lux V at 1.8A, so it should fry a Lux III. Will this work with say a Downboy 1000 or 1200?
gadget_lover Flashaholic Joined Oct 7, 2003 Messages 7,148 Location Near Silicon Valley (too near) Apr 14, 2004 #5 Yes, that should be a good combination. The downboy will limit the current. The pila's put out what? 7 .5 volts? Daniel
Wildcat Enlightened Joined Nov 4, 2003 Messages 281 Location Kingwood, Texas, USA Apr 14, 2004 #6 fresh off the charger, one Pila 150 is @4.2 by my DMM. I put two of them in the 2C mag mod.
