DriverVN4 Coming Soon :-)
vinhnguyen54
CPFBA
[FONT=&quot]DriverVN4
Programming Instruction
Step 1: From Off or On quickly tap the switch 10 times to enter Programming Mode. A dim slow blink will initiate.
Step 2: Tap the Deck number. A dim fast blink will initiate.
Step 3. Tap the number of mode group. A double blink & 1st​mode in group will initiate.[/FONT]
Circuit Temperature Sensor
[FONT=&quot]10-10-F (Default 160F)[/FONT]
[FONT=&quot]F1= Off, F2 = 105F, F3 = 115F, F4 =120F, F5=130F, F6=14F0, F7=150F, F8=160F, F9=170F, F10=175F, T11=185F, T12=200F[/FONT]
[FONT=&quot]
Toggle Programming Lock
10-11-10
Toggle lock or unlock current Mode Group settings.
Any Mode Group in Deck 2 automatically initiates Programming Lock[/FONT]
Turbo Timer
[FONT=&quot]10-12-T ( Default 10 minutes)[/FONT]
[FONT=&quot]T= Time you want Turbo to run[/FONT]
[FONT=&quot]Turbo = Maximum brightness[/FONT]
[FONT=&quot]After entering Deck 12 light will initiate Turbo. Let light run until desired felt temperature and or time. Turn off to lock in Turbo Timer.[/FONT]
Mode Groups
[FONT=&quot]M = Last mode memory. Light will initiate last mode at next turn ON if light is off longer than 1/2 sec. Mode Group without M will always start with 1[/FONT]st​[FONT=&quot] mode.[/FONT]
[FONT=&quot]D = Double Tap. At any mode double tap switch to activate Hidden/Last mode.[/FONT]
[FONT=&quot]F = Firefly = Lowest possible brightness [/FONT]
[FONT=&quot]S = Strobe[/FONT]
[FONT=&quot]
Deck 1 – Simplest
10-1-1 => 100
10-1-2 => 5/100 M
10-1-3 => 5/100
10-1-4 => 100/5
10-1-5 => 25/100 M
10-1-6 => 25/100
10-1-7 => 100/25
10-1-8 => 50/100 M
10-1-9 => 50/100
10-1-10 => 100/50
Deck 2 – Lenders with Auto Programming Lock
10-2-1 => 30
10-2-2 => 7/30
10-2-3 => 1/7/30
10-2-4 => F/2/10/30
Deck 3 – General Users
10-3-1 => 5/33/100 M
10-3-2 => 5/33/100
10-3-3 => 100/33/5
10-3-4 => 1/15/100 M
10-3-5 => F/15/100
10-3-6 => 100/15/F
10-3-7 => F/33/100 M
10-3-8 => F/33/100
10-3-9 => 100/33/F
10-3-10 => 15/100/F
10-3-11 => 33/100/F
10-3-12 => 50/100/F
Deck 4 – Goldilocks
10-4-1 => F/5/33/100 M
10-4-2 => F/5/33/100
10-4-3 => 100/33/5/F
10-4-4 => F/5/33 D for 100
10-4-5 => F/2/25/100
Deck 5 – 5 Level Precision
10-5-1 => F/1/20/50/100 M
10-5-2 => F/1/20/50/100
10-5-3 => 100/50/20/1/F
10-5-4 => F/.7/3/25/100
10-5-5 => F/1/5/25 D for 100
Deck 6 – 6 Level Precision
10-6-1 => F/1/5/15/50/100 M
10-6-2 => F/1/5/15/50/100
10-6-3 => F/100/50/15/5/1/F
10-6-4 => F/.7/2/7/25/100
10-6-5 => F/1/3/10/30/100
Deck 7 – Tactical
10-7-1 => 100/S M
10-7-2 => 100/S
10-7-3 => S/100
10-7-4 => 100/20/S
10-7-5 => 100/25 D for Strobe
10-7-6 => 15/100/S MD for Strobe
10-7-7 => 5/33/100 M-D for Strobe
10-7-8 => 3/5/33/100 M-D for Strobe
Deck 8 – Discos & Bicycle
10-8-1=> 10/25/50/70/100/BikeLo/BikeHi
10-8-2=> 5/33/100/Blink.5Hz/Blink1Hz/Blink3Hz/BikeHi/Blink8Hz/S/Beacon[/FONT]
MikeB.
Iowa
I do like to see the modes that have the double tap for 100%, it's nice to jump quickly to that level from anywhere.
eekazum
Hey, so if you put it into deck 2 and want to get out of it, you need to 10-11-10 and then do another 10-#-#?
psychbeat
SF norcal
I'd like to suggest a simpler 4 flash battery level indicator similar to zebra :)
Happy to see my fav F/15/100 is still there haha - perfect for my uses.
Would be bummed if there's no way to disable turbo timer :)
liteboy
NYC
Other than F mode, I don't see revolutionary changes here. I really wish there were more double click functions (to access turbo or strobe) throughout the decks. Is triple click possible with mechanical switches?
moshow9
El Paso
Will DriverVN4 be available in any of your current lights once it's available?
wimmer21
Kentucky
The general use deck is nice. I like being able to skip firefly and 1% and start at 5%.
10-3-2 => 5/33/100
