Droid
KDM
Tennessee
What size orings does the Droid use? Been using it everyday for over two years and the orings are splitting, time to replace them.
KDM
Tennessee
Thanks, I remembered seeing that but couldn't remember if it stated the size. Guess I'll contact Dave.
KDM
Tennessee
Still waiting on a response from Dave. If anyone has any information on this it would be greatly appreciated.
KITROBASKIN
New Mexico, USA
Do you have the option of going to a hardware store and comparing the stock oring with what they have?
Data
Supporter
PA, USA
You can replace the O-ring yourself if you want. Just get some size #011 O-rings from amazon or hardware store. Please note that is the same size O-ring as the SPY knob uses. To get the Droid apart you use a sewing needle to push in the little hole in the lock lever. The lever will come off and you can then replace the O-rings. The thing you are pushing on is a short wristwatch band spring bar. Don’t let it fall out of its hole in the Droid while it is free from the lock lever. Don't let it get away from you, it is a spring.
Cheers
Dave
