More efficient emitters are being produced every year. Keep an eye out for the latest and greatest. I dont know what bin seoul I have in my 120p, but I believe Ill be switching to a U bin in the near future.
In what way will that change the light? Better output? Better runtime?
Both. When an LED is more efficient, it converts current into light instead of heat. More brightness at a lower curent means that your new "medium high" may be as bright as your old "maximum high". Using a lower setting means longer run-times from the same capacity battery. Plus, you will have a higher high. :thumbsup:
Sounds good! Do you know when it will be available and how much is would cost?
Is it hard to install it yourself?
I just put New U2 in P85. It is as bright now as original P120.
And yes, changing LED will improve runtime on HDS lights, which is beauty of it.
Just program it for lower level, and you will have more runtime.
Cheers. :wave:
Cheers. :wave:
Changing the LED doesn't improve runtime, changing the drive current does.
For instance my U60 with U2 on one level before last one brighten then Twisty 120, and runs about 1hour.
Are there any drop-ins available for the Novatac 120?
I'm looking for better runtimes.
