jimbo231
I went to charge my batteries on my Duratrax Ice and seen that the single cell li-ion voltage setting is 3.6V not 3.7V. Also, my aw r123 cell is 750 mah and I can only change capacities by 100's, so either 700 or 800. Can I still use the charger? If so should I enter 700mah when charging the aw r123 and what will the setting being at 3.6V as opposed to 3.7V do? Edit: I noticed the li-po setting allow you to set the voltage to 3.7V. Should I use that setting?
