Got my DX Q5 into my Ultrafire C2. Not sure if I did the best job of modding, but this is what I got. On a AW protected 18650 I didn't see a difference in output, but I did see an improvement in tint. I took a reading in my bounce box, and I got the same reading I got with the original emitter.. However, when I loaded two primaries, or two AW RCR123's I got a big jump. About 50% more light! I went from an EV reading of 10.2 to 10.7. EV of 10 to an EV of 11 would be double the light. So 10.2, to 10.7, is a 0.5 EV increase. The original reading of 10.2EV puts it around 140-150 lumens, the 10.7 reading should put it over 200 lumens! I would think to get 200 lumens out the front of a light you would need a Q5 to do it, a P4 would probably have a hard time getting over 150-160 out the front.
So does it make sense that going from 4 volts to 8 volts would make a big difference? I'm not sure how the circuit works with the C2. Unfortunately I didn't test with the original emitter with the RCR123's and primaries.
