Drewfus2101
So I spent $10 a piece on 5 of these a few weeks ago. I finally got around to putting them into 3 flashlights last week.
One went into a 2C Mag using 2 x 18650s and a DX board that can accept up to 9V and outputs a constant 800ma. Light output is very disapointing when comparing to other Q2 lights. I have a Q2 running on 1x18650 thats a total thrower, with a very similar beam pattern. The Q2 reads 3 times higher on my lux meter than the Q5.
Next light is a DX light that came with a Q2 running on 2x18650s. I swapped the driver board (same as above) and installed a Q5. Light output is NO different.
I tested this board with a Q5, and with ~8V in, it put out 3.7V (or maybe it was 3.9V) and 940ma at the emitter. So I know the boards are good. So it must be the emitters.
I know what DX will say, just return the lights. Well I can't. They're installed. I might try anyways, as long as they know they're getting them back slightly damaged.
Anyone else have problems with these?
