Hello,
I ordered one of the above to put in a SF G2 and was wondering if anyone else with this same drop-in had modified it so that it would draw less current and thus build up less heat? I did find one post where someone had replaced a resistor with a slightly larger one, but that was all i found and in that case the output was not significantly less. My goal is to make it at least a little more fool-proof (i.e. the user doesn't have to be a conscious about how long it is on) so that as a gift for Christmas it will not fail because of excessive heat.
I can't really justify the price of a M60L for this gift or else I would just go that route; the giftee will not have the same appreciation for the light as I would. I was hoping someone had made a "poor-man's" version of such a drop-in however.
So, is it a simple matter of replacing/adding a resistor or are you stuck with what you get? I'm also open to buying another drop-in if there is one that is more easily modified. I'd like to stay away from multi-mode unless there is a way to cut out some of the modes, which I doubt?
Thanks in advance,
-Jon
Thanks in advance,
-Jon
