I've never actually driven a Honda, but my better half has a fully loaded Mazda 6 and it's a nice car. It feels like someone actually cared when designing it. Materials feel much nicer than what you'll find in a Toyota Camry/Avalon.
At the same time, it suffers from the "good enough" mentality I find in Asian cars.
For example, on a German car the fuel filler door is unlocked when the car's doors are unlocked. On the Mazda, it's locked 24/7, to be released by reaching under the dash (where you can't see when sitting) to pull a lever which is attached to a physical cable that goes to the door latch. Right next to it is an identically-shaped lever which pops the hood via cable. I can't count how many times we've gotten out of the car to find we've not popped open the fuel door, or accidentally popped the hood.
Similarly, the German cars unlock the trunk when the doors are unlocked. On the Asian cars, the trunk is always locked and has to be unlocked every...single...time.
Or the carpeting which doesn't go all the way up beyond where the eye can see, or the lack of cover panels in the footwell where you can't see.. Or the single vent for the footwell vs. multiple vents extending the entire width, etc. AC's weak, by design.
Still a good car though. Very sure-footed when given a proper set of tires.
I wouldn't drive a full hybrid, but wouldn't rule out a mild hybrid. My Mercedes fits under that umbrella, although I have the 12vDC-only version. In practical terms, it means that my car's engine will shut down and/or disconnect from the transmission when it's not needed. We have it tuned so that when I'm driving down road, I can flick the gas pedal and release it quickly to trigger the engine to go into "Gliding Mode." and the engine is decoupled from the transmission and the car coasts. If the aircon is on, the engine will idle at a very low RPM to keep that going. Very little extra complexity and no lithium batteries.
I did drive a newer Mercedes with the 48vDC system and it was seamless. It was kind of unusual to see the engine go to 0 RPM so early and for so long. That version has no 12v battery at all, and just a 1kWh lithium battery. BUT, the engine has no belts. Instead everything is electric and it uses an oddball combo starter/generator/motor thingie(TM), which can move the car forward. If you let into it, the car will use both the electric motor and gas motor. Launching that barge 0-60 in under 4.5 seconds is admittedly fun. Too bad they've beaten all of their new models with an ugly stick on the inside and outside. Enough that I wouldn't buy one.
