Gman
I was reading a thread over on the SF forum regarding this. I agree with F/C, the E1/E2 is quite water resistant. It may not be a dive light and hold under the pressure of several atmospheres (as I recall every 33 ft of sea water is one atm, at 33 feet you'd be under two), but it does very well otherwise.
I submerged my completely assembled E2 for 1 hour with the tail cap one turn out, it was completely dry afterwards. I then turned it on and ran it through a set of batteries underwater and watched for bubbles since I assume the heat would expand the air inside and show leaks. Again, nothing happened and it was dry after. Since I saw no bubbles, this means the light was tight and the slight positive pressure from heating may actually help to keep the H2O out.
As long as the bezel is tight and the O rings lubed, I see no water issues in normal use at all. I also noted that there is sufficent room on the tail cap end for machining another O ring groove next to the stock one, but it seems uneeded. (I may do it anyway) Btw, I don't know how the lens is sealed but it didn't leak either.
The only weak spot could possibly be where the rubber pushbutton contacts the inside of the tail cap, but as long as the batteries are loaded and exerting force to seat it, it seals fine. (This is why the first test was with the cap out one turn, tightening it down so the lamp is on really seals it.)
Just for grins, I applied a little grease to the "flanged" part of the rubber button where it meets the ID of the tail cap anyway.
Btw, I use Dupont Krytox, this is PTFE (teflon) grease. Very expensive but the best you can get for this kind of work.
Seems to me other SF with the same design (6P, 9P, ect) would perform the same.
I also submerged a Ultra 123 battery alone for 30 minutes prior to the test as I was concerned I would have to machine up some dummy batteries, but there was no reaction at all and it functioned fine afterwards.
I think people may be confusing Lithium with Sodium, which you for sure don't want to get wet, but I'm no chemist.
Any Comments? Opinions? Flames?
