E2e lamps
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
Hi everyone. I've bought several E2es over the last couple of months, each of which came with the papers. On the little silver book that comes with them, it says E1e/E2e Executive Elite Lithium Powered Flashlight and them gives the lumens ratings for both. It has always said 15/60 depending on the model E1e or E2e. Well, I recently bought an E2e-CJ and the ratings are given as 60/90. Is there a 90 lumen lamp for these lights (HOLA) or is this a typo? The 15 is left out altogether. On the inside of the book, the normal specs are given.
Your CAMO came with the MN03 probably, which is the high-output lamp assembly. The MN02 is the low-output version, which extends runtime on the E2x to 2.5 hours.
I forget the colors of each on. I think the black colored one is the MN01 for the E1. I don't remember if the blue is the MN02 and the white is the MN03 or the reverse.
I believe it came with the MN03 and you're right, it is white. I just checked the MN01 that came with my E1e and it's black. I haven't been fortunate enough to get an MN02 yet. I just can't figure out if that's a misprint on the book. All of my other books have given the correct info. I thought maybe I had been missing out on a 90 lumen lamp, but I guess it's a typo.
Can someone compare the MNO2 lamp (LOLA) against the KL1? I have put off getting an MNO2 because the lumen ratings were so close but now I am thinking that the MNO2 definatly has a place in the armentarium!!! See my B/S/T offer. Thanks.
Bushman, I think what you get with the MN02 is a real beam with a bit more throw for an E2e without the length of the KL1. On the otherhand, you don't get the white light of the KL1, nor the regulated runtime. That's why I don't buy myself a MN02.
Al
