E2O clip problem
Stingray
Chicago
My new E2O has developed a problem with the clip. It has become loose where it attaches to the body. It's not that it's loose in terms of tension against the body for holding it onto the pocket or belt, but it is loose in the the slot that it mounts into. It wasn't like this at first. Is there a recommended way to tighten it up or do I need a new clip?
I did...they are sending the little spacer to put in there instead of using the nylon washer.
Customer service is sending me the washers and the plugs, I plan on usuing them both for a really good seal.
