Edge Tactical
Re: Eagletac D25 Clicky Series Round-up Review (D25C, D25A2, D25LC2 - XM-L & XP-G)
I love my D25C clicky.......what a pocket rocket!
Yes, my Spark SL6 is about the same brightness initially. The D25LC2 drops down less than the Spark does, after the timed step-down. Interestingly the SL6's Hi mode is almost about the same as the D25LC2's. The SL6 does have more throw, of course.I orderd a D25LC2 (18650 XM-L U2) a couple days ago before this review. It looked to be smaller than my Spark SL6 800cw but just about as bright. It looks like this data confirmed that.. especially since Turbo on my Spark only works with very freshly charged 18650 batts and only for a very very short time.. so mostly the highest I get from it is ''high'', not ''turbo'' anyway. Looks like my new EDC.
Yes, the lack of flat-top support will be an issue for some.No Eagletac for me, no support for flat-18650 head-and the 2AA version, is just like mine Fenix E21.
I like throw indeedYes, the lack of flat-top support will be an issue for some.
But I'm surprised about the Fenix E21. On Max, my D25A2 (XP-G S2) has about twice the initial output of my E21 (XP-E R3), and exactly the same runtime on NiMH. On the E21, you also only get two modes (i.e. you also have a much wider range of modes on the D25A2). But the E21 still manages better throw, thanks to its larger head and smaller emitter ... I presume that's why you find them equivalent?
And if I may, as a relative newbie flashaholic, I'd like to offer my interpretation of the term "moonlight" mode. I may be entirely wrong, but I think some folks are thinking of "firefly" mode when the term "moonlight" mode is referenced.
It seems that I've understood the following (primarily from readings in CPF, but subject to change and totally open to correction! lol):
Moonlight Mode =
Rather low lumens (10, 7, 5, 3, etc.) for generalized low light needs such as night vision preservation, night reading, generalized battery conservation and so forth.
Firefly Mode =
Ultra low lumens (3, 1, .5, .03, etc.) primarily for extreme runtime needs such as elevator entrapment, lost in wilderness, map reading, and so on.
So in my mind, when I did briefly own a D25LC2 Clicky, it did have a "moonlight" mode.
Disclaimer: I may be totally wrong, but at the chance of utterly embarrassing myself, if my unusual observations can help clarify an item of curiosity or contention or even inspire a different way of viewing a subject.... then that risk I shall shamelessly sometimes take! Hey! I should put this statement in my signature once I realize there's not exactly a whole lot of point in listing my lights there anyway.![]()
As melty said, it is largely a question of semantics. But in my experience, most people mean the same thing by "moonlight" or "firefly" mode - that is, less than 1 lumen (preferrably considerably less). The terms are really used interchangeably here.And if I may, as a relative newbie flashaholic, I'd like to offer my interpretation of the term "moonlight" mode. I may be entirely wrong, but I think some folks are thinking of "firefly" mode when the term "moonlight" mode is referenced.
What about operating 'memory'?
On my Fenix, if I switch from regular to Turbo, and then loosen the head, it resets to low regardless. With 4Sevens it reverts to the mode you had before initiating turbo.
What does the D25LC2 do?
and what is the CCT of the neutral xm-l and xp-g? Is there really a 4300K T6
The first instance of "moonlight" that I can recall was the 4Sevens Quark line (0.2 lumens "moonlight" reported). This was used to differentiate it from the traditional "lo" modes of Fenix and other makers, which typically were in the low single to double-digit lumen range.
we cant have it all, i guess. i was about to order the D25C only because it had mode memory (and is much brighter) .. but the D25A has to be bright with 14500 too and is more light-weight (24g vs 29g) and slimmer. the proportions look better imho.and wish the Eagletac did work like the Quarks with that General mode memory
Similarly, I don't think most here would accept "firefly" to be anything more than a fractional lumen.
I know it may not sound like much, but even a couple of lumens will seem blindingly bright to you with dark adapted eyes. IMO, the D25LC2's Lo modes would not qualify as "moonlight" by a long-shot.
Good question. I don't have the lights in front of me, but I recall it does have 'positional memory' of at least a few seconds. I recall turning one of the lights of in "second C" once, and when I turned back on after a couple of seconds (not long), it continue along to strobe when I tried switching modes. But I didn't set out to measure the interval, so I'm not sure how long it is. I'll take a look when I get the chance ... anyone else already try it?Another question, this time about 'positional memory'.
Let me expound: if the outputs go as such A->B->C->A->B->C->Strobe->Strobe->Flash->SOS->SOS->Beacon->Flash If you selected the second C setting, but used that for five minutes, would the next press be Strobe, or would it go to A?
Going to A would be more useful.
