FlashCrazy
So when is the Mark II for sale I havn't found any info on release date yet.
The Mark II can be ordered by dealers now, so you should start seeing them for sale sometime next week. 🙂
Help Support Candle Power Flashlight Forum
I'm happy about the OP reflector. IMHO, one of the only flaws of the P100A2, and main thing that kept me from buying the old T100C2 was the smooth reflector. It throws great, but there are some minor artifacts. In my experience, the finish doesn't affect the beam throw that much unless it's a heavy stipple; the new T100C2 should still throw well.
The T100C2 MKII seems like a step backwards from the things I find most appealing about the first version.
I have 0 interest in this one. :ironic:
Have u personally seen the beam on the t100c2?
Its wayyyy smoother than any Q5, the artifacts are very negligible. Don't even have to mention real life usage. I've only tested 2 lights so I'm not sure if i actually got freak lights that are smooth though. But I'm guessing its overall pretty smooth.
So I am wondering if u really need an OP for this light.
It was clearly meant to be a throw light anyway (the flood is small compared to other lights).
I've compared side by side an OP and a smooth reflector on the same model of light, it does affect throw a little bit (which is noticeable).
Personally the changes isn't fantastic enough to make me get it to replace the original one. The bezel already seems fine to me unless someone wants to use it as a hammer...
I don't want the optional OP seeing that the beam is already very smooth and i want the THROW.
I have the P100A2. The reflector is a bit smaller than the T-, but otherwise similar. Mine has a faint dim spot in the center of the hotspot which can be distracting to me, even in "real world" use. It has the best throw of any 2xAA light according to Selfbuilt's reviews. IMHO, a LOP reflector would clean the beam up while still allowing good throw. The XP-E is nice, but it isn't perfect.
The 5% wouldn't be noticeable but its still quite an improvement.
I wonder how they did it.
Better reflection material? Extra 'smoothness'? Very interesting.
Hello all,
The bezel on the new T100C2 is stronger, but it does not change the overall weight.
Nicole
Read this:I'm interested to know how the waterproofing has been improved. Thicker/more o-rings? Different locations? The product page notes that the operation is now smoother. Was that an issue on the MkI?
It says it's the same, not improved. It's smoother now but it was smooth before, no issues in MkI.Now T100C2 Mark II operates smoother and still maintains excellent waterproof ability.
