Eagtac D25LC2vn - Slim 18650 thrower
Skylumen
Purchase & Deails: https://skylumen.com/products/eagtac-d25lc2vn-slim-18650-thrower?_pos=1&_sid=6a0db9470&_ss=r
1100L and 50Kcd from a 22.5mm head... that's just crazy. Even the the FW3 has a 25mm head.
Whoa... 22.5mm head with 50k cd?! That beats out even the Goliath V2vn! Boy am I wanting one of these...
What numbers does this put out with W1.1??? 65kcd / 800 lm?
On a P60, the variance between those LEDs is only 8Kcd and the output is about 1/2 for the W1.1 The difference between the W1.1 and W2.1 in a smaller reflector will probably be even less, perhaps 5Kcd. In each case, I'd have go for the noticeably higher output and 5400K of the W2.1. The throw advantage for the W1/W1.1 seems to be greatest with medium/large reflectors and optics.
I really like this light other than Eagtac's UI.
I actually really like the head tight - head loose interface of the EagleTac /4sevens / Armytek.
Is it possible to have this light retain that factory interface, but use the new White2.1 'thrower' emitter?
Yes, also curious if this is available with W2.1 & factory interface. Looking for a rear switch, 18650 thrower, 28mm head or smaller, 45+Kcd. VN4 probably puts this a little out of my price range right now.
To this day, has any light under this 22.5mm head size surpassed the throw of this little monster? 62kcd for 22.5mm head is insane, but this came out nearly a year ago.
Can we hit 70-75k with anything in this head size today? What advancements need to be made to accomplish such a feat?
And what else is comparable in head size to throw ratio?
