<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by bushman:
I am new at this and want to put 3 luxeon stars with optics in a 3d mag lite (although open to other case suggestions) What is the best and most cost efficent way to run these and get the best light output?
Do they have to be regulated or resistered or both?
will the optics cause the beam output to be three separate beams? If so i might want to consider just using the bare luxeons to get a more broad expansive "flood" beam. any input will be helpful but i need the most help on regulating the power and the proper way to hook them up... Thanks.<HR></BLOCKQUOTE>
You'll have a big job heat sinking these 3 Luxeons, but I think the MAG LITE should be able to do this, if you use an aluminum plate and sink the heat to the flashlight head and body.
I would suggest you use a 5 'D' cell flashlight,and use a step down regulator in a 'D' cell dummy, set at 3.2 volts. (I make a step down regulator that would do this.) Three Luxeons will draw 1.05 amps, which is reasonable, with a light output of 54 lumens, which is very bright. If you try a step up regulator, you'll have problems because of the high current requirements of 1 amp. With the step down, your light will be full brightness until the batteries voltage drops to 3 volts or so, which is 50% expent, which is also okay. Run the Luxeons in parallel and not in series. I think this would work, although the flashlight will be huge!
I did an experiment using just 2 Luxeons, with 8 AA batteries, and my step down regulator, and I thought it was really super bright. I just mounted the Luxeons on an aluminum plate, not a flashlight.
Three Luxeons would be totally awesome!!
Oh, the light from multiple Luxeons blend togehter beautifully, as one single bright focused beam.
Wayne
