D
**DONOTDELETE**
Guest
Just take some coax cable and snip a small peice off. Push on one end with small pliers.
Pull the guts out from the other end and put it on the LED. Make sure you get the wire mesh out too. Sometimes this sticks to the sides of the cable. Don't use the good quality contractor grade coax cable for this project as it is slightly bigger than the cheap stuff and will be too loose. Also you have to make a real straight cut so the light doesn't bleed out and make a funny pattern. It has to be real tight against the body of the light.
