Noticed an indexable 3/8" boring bar for about $20 on ebay today, wondering if it's worth the money, or if I'd be alot better off just saving up for something else.
Lots of differing opinions, but I would strongly suggest you pass.
Quality American,Japanese or European ( Sandvik) tooling is really worth it.
And they don't have to be new, but give some thought as to what you are going to be using your lathe to build.
If its flashlight related, then I would recommend a triangular, positive insert so you have 3 tips as opposed to 2.
Triangle shape works well for boring and turning so the same insert can be used in both tool holders. Under no circumstances get negative inserts. Positive only for light machines, to cut down on lack of power, vibrations and the fact that you might ( flashlights) be dealing with thin walls.
Also top rake insert geometry is so important. For aluminum, Sandvik recomend 20° at the tip and 25° further down. They call this geometry AL.
Also for aluminum, get a ground super sharp finish by specifying 'H10'
that is uncoated carbide that is perfect for Aluminum and as it just happens is also very good for Ti and SS ( small finishing cuts in Ti and SS only, due to AL geometry. Expect to pay retail $10 per insert and $100 for a holder, boring or turning. If your toolpost can handle 1/2" square shank, get this. Prices on ebay will be less.
So TCGX 2(1.5)1-AL H10 would be my sugestion as a superb all around insert that will be worth every penny.
NOTE:
The above sugestion is bases on the presumption that your depth of cut
will be low. Then I think this one insert, with its 7° positive front rake will work for boring as well as turning. If you were to take large cuts when boring , 11° would be prefered so the second letter would be 'P'
EXAMPLE TP** *****-**
Hope I have not confused you too much........
