Thanks to a sugestions by Newbie, I am using the TI/Burr-Brown INA196 Current Shunt Monitor, along with a highly accurate Ohmite CS3 Series, 4-terminal 0.01 Ohm current sense resistor (1% tolerance). I am using a standard 9V alkaline cell (the small 5mm RED LED draws less than 2mA if I recall) and this drives a standard 7805 to get a nice and stable 5V to the INA196.
The circuit that I build it shown here:
Here are some pictures of the actual pieces and project:
EDIT: Pinout for the INA196 in the diagram is not correct - I am re-using a part in DesignWorks Lite . Correct pinout is:
1 - out
2 - gnd
3 - V+ (supply)
4 - Vin (-)
5 - Vin (+)
The problem is that when I turn the circuit "ON", I get a "nominal" 26.7mV on the output, even when I have no current flowing through the LED. When I set my bench supply to turn on the LED at various currents (100mA, 200mA, etc.), the output voltage does get proportionally higher, but I always have the same "offset", plus the gain is all messed up (I get a factor of 7.1 times the mV reading in the voltmeter to match the accurate output current reading on my bench supply). According to the data sheet for the INA196 there should be no offet - voltage is zero when the input current is zero, and it should have a gain of about 20.
Any ideas that is going on? Suggestions?
Will
1 - out
2 - gnd
3 - V+ (supply)
4 - Vin (-)
5 - Vin (+)
Will
