You know, I remember Peter saying the efficiency of the regulator in the ARC AAA's was around 80% (or a little more?) Anybody know what the exact (or approximate) number is for the ARC LS and the newer ARC AAA's? Peter?
Peter,
Speaking of regulators. Is is possible to create a different model of the ARC LS, were the regulator is designed so that you can use 2 regular AA alkalines and it be as bright as the current production LS with 2 AA lithiums?
You wouldn't be able to use lithiums in this model because it might push the Luxeon too hard. But I would rather get the brightness of lithiums with less expensive alkalines. I'm sure battery life would be shorter but I would prefer the higher brightness.
Roger, the efficiency of the LS inverter varies around 70-80% depending on cell voltage, tempurature, etc.
Sean, like all our products, we can't leave them alone and are always making improvements. I have been working on a new design for the LS for some time now and probally will be for a lot longer. I think you'll approve of the improvements.
Uh - Peter - Efficiency numbers aren't exactly a trade secret once you ship a product - after all, anyone with a bench supply and a couple DMMs can measure Vin, Iin, Vout, and Iout and thus calculate (and even plot, using some HPIB equipment and HP-VEE software) your product's efficiency.
As shown on this group, reverse engineering is a common skill. Publish your "performance data" and people will be less likely to do it for you (and perhaps mis-spec your product!)
