proper ? oh oh, is there such thing when there are many methodologies/alogrythms. Proper is more based on the design/type of the charger, and the intention of it.
if you go all cheap, proper would be to keep the rate low, make a dumb cheap charger keep the rate really low, and everything will work out ok, because you dont go over specs. then have a very sensitive termination, which can sometimes fail and leave you with a 20% charge battery.
proper for a "smart charger" or fast charger is to insure that pressure temperature or voltage drop are monitored, and it stops at overcharge.
Proper for a 350ma charger would be to monitor temperature, which is almost impossible due to changes in ambient temps, or use a Voltage 0 detect instead of a voltage drop. if the charger looks for the voltage to stop going up, instead of start going down , then it can terminate easier at lower charge rates. that should be very good, but it can fail too, just like anything. stuff like that can fail by terminating EARLY, the battery not fully charged.
about anything will charge a enloopy, and most of the things sold and recommended wont damage it, and rates vary from 230ma (averaged) which is a very slow rate , to excessive speeds like 8000ma , which arent good for anything except speed.
the 900 and the 9000 are different, but not that much different, they have the same basic functions, just applied differently by the programmer. one says tomAto one says tomato. you can do a slow or fast rate charge with either. just the 900 doesnt have timer termination for a 200ma rate, the 9000 can do a "forming" thing and terminate on time. the 900 really cant, unless you include charging to slow for termination. the 9000 doesnt get stuck with a 1/2 rate discharge function.
You mention the use of high mA currents to prevent overcharging. What is wrong with charging 4 batteries and just manually terminating the last to show its full by just removing the battery at 1.52V to prevent a missed termination
i mentioned high rates to insure termination
which prevent overcharging or baking of a cell. but things are indeed happy to go slow TOO with a charger that works in that way.
these 2 things the 900 and 9000 are designed to terminate based on a voltage drop from what i understand, if they dont get it, they bake the battery. they dont terminate on the taper, the terminate on the drop, so you slam the battery till it gets that drop, because just tapering off to 0 change isnt the way they work.
There is Nothing wrong with terminating the charge at some set voltage, but i assure you it will not always be 1.52 volts for 99% charged cell, some cells you can pull at 1.55 and they are only 80% charged, in TIME i would bet that the enloops will start acting aged , lots of time.
Also when the cell is not vibrant, when the resistance of it is lower, terminating at some set voltage the cell would not be fully charged.
for example if you let that cell park unused for some 6 months, and come back to it, it will terminate at a higher voltage.
some cells terminate before that, like at 1.47 , and again at some rate of charge. the rate can cause or not cause the overcharge state to occur at different votages, it is a unreliable method to assume completion at that point, and by removing the battery it will not "finish off" with the topping charge.
AlTHOUGH
there is nothing wrong with terminating any of them at say 1.4v and continuing to top it off very slowly. in my opinion that would be Much better than the present "smart" methods. Or just having it at 80-90% and using it that way. there is nothing wrong with Not reaching overcharge states, i dont like overcharge states, and neither does the battery.
the wrong occurs when it sits on the fence of the overcharge state, at an overcharge rate, and just heats up.
Yes all charging methods charge up the battery, so yes they are all the same, but some do more or less damage to the cell, between charger damage, and reverse charge damage in series configurations, that is probably MOST of the reasons a cell doesnt do 1000 cycles, but more like 150-200.
if you can stop all charger damage, and reverse charge damage, then you have happy long living cells. probably somewhere in Pleasantville or the emerald city that can happen
