eneloop longevity
wshyang
I recently cracked open a package of re-branded first gen Eneloops. Package is marked 2008, purchased in September or October of 2009.
After one R&A cycle on the C9000, I had capacities of around 1770mAH for one pair and closer to 1810mAH for the other two and I think impedance check of (?) of 1.6 to 1.65.
Charge rate 1000mAH, discharge rate 500mAH. I'm running another cycle right now!
Oh dear, I have quite some from 08 and some from 06 even. So these things don't fare too well when in storage?
Shadowww
Banned
Northern Europe
You should try break-in (if you don't have much time then single 2000mAh break-in, if you can wait then first 1900mAh break-in and after that 2000mAh break-in), I've noticed that it restores capacity much better than R&A on LSD batteries.
Don't forget to discharge batteries before doing a break-in, some members here saw noticeable mAh gain by doing that.
tickled
You should try break-in (if you don't have much time then single 2000mAh break-in, if you can wait then first 1900mAh break-in and after that 2000mAh break-in), I've noticed that it restores capacity much better than R&A on LSD batteries. Don't forget to discharge batteries before doing a break-in, some members here saw noticeable mAh gain by doing that.
The second R&A just wrapped up and it improved: 1880, 1877, 1893, and 1866 were the numbers that I had. I will do one more within the next few days and see what the numbers look like then.
tickled
I did a discharge and then immediately started another R&A after while the batteries were still warm (I was in a rush) and the impedance check was in the 1.4 range with final capacities ending up at 1866, 1867, 1875, and 1845.
Bolster
Mexifornia
Adding a "research note" here. I've been using the Burn In Mode to revive some old cells, and by BIMing some with reduced capacity at 1900mAh, I think I've been killing them off. Noticing reduced capacity after each BIM. Likely culprit: setting 1900 as capacity, instead of 1600 or 1700 as appropriate.
Posting this so people don't make the same mistake I did. More info at the "Dying Eneloop" thread, if you're interested.
Based on what I know now, I'd never BIM at 2000 or even 1900 for old cells, until I had a better fix on their capacity. If rehabilitating old cells, start your BIM on the low side. Maybe 1500.
Two, and possibly three, Eneloops were murdered to bring you this information.
