I got mine this morning too. I like it- well made and brighter than these posts have led me to believe- perfectly respectable as a reading-light or to provide a soft background glow. The light is pure white, although the 2 LEDs are different colours. One is a cold (ever-so-pinkish) daylight-white and the other is a little yellowish in comparison- they could have matched the 2 diodes which would improve the look but it`s no big deal, this is to be expected of white LEDs.
Here- I`m using it as a keyboard light. Note the usual mess
BTW the missing keys have been removed on purpose- I never use them (insert-overtype mode/popup menu/Caps Lock)and got tired of hitting them by accident while typing and looking up to see something really crazy had happened and wiped out half what I`d typed or it was all in capitals or something. They need to make the keys bigger, then I`ll be OK....
<center>
</center>
This room, after dark, is normally just lit from the glow of a handful of monitors (TV/PC/CCTV) and a string of dim yellow LED xmas lights (that used to be battery powered but now run off a lab power supply)- which is enough for general browsing or tweaking web pages (assuming the screens show light coloured images)- but when I write a lot (like emails or all these posts) I could do with a little more. Even on one "tube" it`s great like this. 2 tubes, obviously, are better still. Actually it seems to be more than twice as bright on 2 as it is on 1, the meter reads 200mcd on one but 700mcd on 2- not sure of the accuracy of my meter at such low levels, it reads in multiples of 100mcd lowest so could have been a high 200 and low 700 for all I know. Remember that peak beam candelas are a function of the beam angle- the overall output isn`t bad for 2 LEDs, it`s just spread out a lot.
Full power easilly lights the room when I hang it up in the middle- not brightly, but enough to see my way around the piled boxes and avoid stepping on trailing 3-pin plugs (which hurts like mad if you don`t see one in the dark, and do so like I did last week- still hurts
A nice one for camping or perhaps reading in bed without disturbing others. Nightlight? Current draw is 32.5mA on one led and 63.9 on 2 leds (these may be a few mA too low due to meter losses) and the claimed run time is 100 hours high and 200 hours low. Wonder how close it will get to those figures- anyone know the maths to work it out, assuming Alkaline AAs?
I don`t know how hard it would be to add an external power jack to one of these but if it could be done, a wall-wart could run it after dark in a hallway or bathroom with no worries about recharging or replacing its batteries. Worth looking in to when my testing is done.
