Energizer rechargeable 3 watter
defloyd77
Wisconsin
I came across these at Wal-Mart, they have a nice beam, reverse side clicky, very easy to push in the package, 1 reddish filter and 1 green, smooth bright beam, car and house charger for about $50. I tried finding somewhere with that flashlight for information, but came up with nothing. Anyone know anything about these, I'm mostly curious about the battery type.
I just purchased one of these last weekend. I really like this light! It is bright and has a nice white beam. However, the battery is an oddball. It has "1/2A 1000mAH 3.6V, 20070430" stamped on it. The battery is composed of three cells that are each just a little larger than a CR123. It is a NiMh battery. I would like to find a source for these batteries, and possibly get one with a higher capacity, or maybe a Lithium ion version. A 18650 will not squeeze into it. I may return the light if I can not find a source for these, but it would be a shame! I was experimenting and put two CR123's into it and it worked using a home made spacer, but I only used it for a few seconds. I am not sure if the LED can take 6v. If it can, actually my search for other battreies would be over! Anybody have any insight into this???
Mike
Correction to may last post: The three cells that make up the battery are each a little SMALLER than a CR123!
Mike
Same here. I got it as mostly a back-up rechargeable in case anything happened to my Inova T4. I'm also hoping that the cells for it are sold seperately as well.
