Beacon of Light
- Joined
- Dec 9, 2005
- Messages
- 2,087
Voltages were 1.19 for the Eiger #Subzero, 1.10 for the iTP A3 and .97 for the Eiger #0
Help Support Candle Power Flashlight Forum
I also took off 4 Duraloops that completed the refresh cycle. Since that involved it charging to full and then doing a slower discharge and charge and discharge repeatedly till it was optimized, that should have formed the batteries properly, effectively getting them broken in correct? They all read 800+ mAh so they should be good to go correct? I will test the problem lights and see if their results change. I'm most interested in the E01, Maratacs, Preons and the LF2XT since they seem so off from what they are "supposed" to be able to do on low mode. The other 4 Duraloops are still being refreshed and I am at work now but they should also be done when I return later tonight.
I think part of the discrepancy is est. runtime for some of those lights are based on Alkies(which I believe are rated at ~1200mAh).
Beacon,
At 4:30 pm ET, I had 4 refreshed eneloops reading 1.46 volts off the charger @ 800+ mah each
I fired up the following:
Fenix E01
Peak Eiger #1 Luxeon
Peak Eiger #1 XP-G
Ti Preon on low
Quark on moonlight for comparison
I'm doing this to see if I at least get similar results on the E01 and Preon as you did with the same batteries. The Peaks are for kicks, but it will be interesting to see how the Luxeon does vs. the Cree.
Will keep you posted
This is exactly right. The E01, which you got 11 hours from sounds textbook for NiMH, if you want those insane moon mode runtimes, you have to do alkaline, NiMH and lithiums will give you better sun mode, but then drop like a brick. The simple sad fact is, your results reflect exactly what I thought was going to happen and why I don't give lights like the iTP much credit when they boast these ludicrous "50 hour" runtimes. I don't at all feel your tests were flawed due to the Duraloops, between your 2 tests, the numbers look consistent, I don't think you did anything wrong here.
I think the lessons to be learned, don't believe in stated runtimes, simplicity reigns supreme (the simple 1 mode unregulated Eigers) and although they suck in high drain applications, alkalines are going to give you really huge runtime numbers in lights such as these.
Thanks for doing these tests and also for your part in bringing the #0 and Sub Zero into the flashaholic world.
Now, where's that Mortal Kombat guy? "Sub Zero wins. Flawless victory."
One particularly important reason for this is that a PWM regulation microcontroller sucks anywhere from 6-10mA most of the time (that's with an ideal picoPower AVR, which are essentially the most efficient at 8mhz. If they're using a different micro at high speeds, it could suck even more.). As I said, depending on the design it could suck even more than that. That means that it's sucking as much as the LED, maybe more, on low mode. With the peak, you don't have to worry about that as it's only 1 mode, linear regulated (or not regulated at all?).simplicity reigns supreme (the simple 1 mode unregulated Eigers)
