knifebright
Hey all
I need a little help with measuring current. I've done a bunch of reading last night and I believe andrew w had some very good ways of estimating the current over the emmitter. However i need some more help. What i can measure is
current from battery end
forward voltage of lux
voltage of battery
voltage under sag
Now I know that power=voltage*current. I can use that formula to figure out wich ever variable is missing. So if i can get current from the battery end, know the voltages and can factor the power, where do i go from here to guestimate amperage at the emmitter end. The point of all this is i'm trying to figure out if and for how long my nexgen 750 is running in regulation, or just in safe mode.
thanks
jimmy
voltage of battery
voltage under sag
thanks
jimmy
