Between these two lights I wonder if the Fusion will be better since its going to be using 6 LEDS instead of the 4 found in the Eternal. Does anyone know what the specs are going to be on the Fusion unit?
I would think the Fusion would be brighter. It will use the same IC chip as the Photon III giving three levels of brightness. Six LED`s and the reflector may help some too. The mix of narrow and wide LED`s...well I not sure how well that will work...sounds good though.
