Well I got my EX10 today and I must say that I am disappointed. It will not latch on when the head is totally screwed down. It will come on when I press the piston, but as soon as my thumb leaves the button, the light goes off. I can only get a tactical mode out of it. I have emailed The Fenix-Store and I am sure that it will get take care of, but I am still not happy.
Adimag, we want to make sure you're happy. We already
replied to your
post on edcforums as well as responded to your PM and email. A replacement
for exchange is on the way to you. If you look at the brass contact ring inside
the head, there is a split in the ring. The gap needs to be slightly enlarged with
a tweezer or small flat-head screwdriver. But don't worry, another unit is
on the way to you so you won't need to do that.
I've tried to duplicate the emitter glow issue on my EX10, but cannot.
I'm not holding back my enthusiasm for this light, but perhaps my higher-end lights have jaded me somewhat. I will say that this light gives the best bang for the buck of any light I currently own -- but it's not the best light I own.
Other thoughts: The knurling seems just right. The tailstand with lanyard attached is cool. Button seems stiff, but I haven't cleaned and lubed it yet. Finish is flawless. Seems like the UI catches on with use -- simple enough, complex enough, elegant enough.
You will need to send that light back if it has an "after glow." NiteCore QC
reports about 0.5% having this issue. We will swap out that unit for you no
problem. Please email
[email protected]. Thanks.
I noticed a small issue with my D10 which I didn't see before. It would seem that the o-ring at the lens wasn't quite set in place when the light was assembled. The green arrow points to a portion where the o-ring is fully seated and not really visible. The red arrows point to where it seems 'squeezed out' a little... and you can see the left section is even frayed a little.
If this is only an aesthetic issue, I don't really care. It takes pretty careful observation to notice and doesn't impact the beam at all. I'm not much of a nitpicker.
The only thing that concerns me about it is whether the water resistance is compromised. Opinions?
There should be no problems with water resistance. This is due to
the small movement of the oring when the light was assembled. If there
are any indications of water leakage, we'll exchange the light.
