donn_
Here's an interesting little heavyweight:
That's 14+ ounces of solid brass, hosting a Malkoff M30W. It started life as a dim little 2C incan. The body walls are better than 3mm thick, and the switch is a built-in twisty.
I tossed the wimpy reflector and modified the threaded bulb holder to act as a keeper for the Malkoff. I needed a strand of 3 twisted copper wires around the drop-in to center it and provide the circuit. It's currently running on 3x 2/3A NiMH cells, but does just as well on a single AW C Li-Ion with a spacer. Unfortunately, an A123 26650 is a little too fat to fit.
I'm still polishing it, but have started thinking about sending it off to one of our talented lathe-men to have that brass carved up a bit.
Any style/design suggestions would be welcomed.
