gcbryan
My Uniquefire HS-802 arrived today along with the 50 mm aspheric lens I ordered.
I tried to replace the switch with some forward clickies that I have but I wasn't initially able to make everything work correctly. So, for the moment I replaced the original resistored reverse clicky with a regular reverse clicky.
I don't need two modes for the particular light and I dislike two modes when those modes come from a resistor in the tailcap. You click to turn it on high, another click for low, and a third click to turn it off...annoying.
I also was able to replace the tailcap button with a pistachio (green) one. Hey, I like them!
It's not dark yet so I haven't been able to try the light out. I did verify that I can get the bezel off and could take the reflector out easily. Since this came from DX I'm excited just to have it work on arrival!
I've borrowed a bench belt sander so I'll have a go at trying to grind the lip off of the 50 mm aspheric later. It will take more than that as it's not in focus when it simply replaces the standard front lens.
With more grinding I hope to be able to slip it down the head to the point where it is in focus and then I'll work on how to mount it there.
I'm thinking about seeing if there is a standard size PVC pipe that would work. I would cut the pipe to the focal length, glue the aspheric on one end and glue the other end to the head assembly after removing the reflector.
For today, I'm just going to test out the throw with the reflector and try a little glass grinding just to see how that goes.
It may be that the focal length is short enough that it won't be in focus until after the neck narrows. If that's the case there would be little point to modifying this light. I already have a P60 host with an aspheric.
I also have a 42mm aspheric and a 41 mm head flashlight due to arrive soon where I plan to try the same thing so I have two chances to come up with something that throws further than the 28mm!
I'll also going to do a rough test tonight using a tube from toilet paper. I have a light where I can easily get down to the bare emitter and can use it like a candle. I'm going to slip the light down the tube to the point where the emitter is in focus (with the 50 mm optic held in front of the tube).
I should be able to roughly compare throw with the 50mm and with a smaller 28mm.
