OneBigDay
I have read a lot of posts in the past few months were people are complaining about the LED domes being knocked off. Usually this is not accompanied by a full explanation of how this happened. I am wondering if this is only something to be concerned about if you are doing mods and pulling the PIL apart, or if this is a more widespread problem. I am not talking about the case where people are removing the dome on purpose.
My observations so far seem to be this is more common with Luminous LEDs, and it also seems to be happening mostly when people are trying to focus drop-in reflectors or doing emitter swaps (mods). It seems that actually touching the dome is the shortest path to knocking it off. This is kind of the crux of my question - is the dome still somewhat fragile even if you do not touch it?
A lot of marketing hype has been put out there that LEDs are "virtually indestructable". If the optic/dome is an integral part of the LED package (which I believe it is), then how indestructible is the whole package in practical use?
I would like to hear the subject matter experts explain why is the dome fragile at all and how much does this vary between different emitters? I would also like to hear peoples comments or experiences with actual use cases in the following scenarios - which I would hope is normal use and would NOT result in a broken dome.
1) Weapons lights (can the impact from firing a weapon remove the dome?)
2) Bicycle use (say handlebar mounted on a hardtail bike on a rough trail, could this result in the dome coming loose?)
3) Accidental drop of a flashlight onto a hard surface where the host comes out reasonably ok.
4) Normal holster or bag use where the flashlight might take a few indirect hits but nothing purposeful or abusive.
5) Simple handling of drop-ins (moving between hosts, in/out of storage, etc)
6) Epoxy aging. Anybody familiar with CD rot? Your precious music/data is archived forever, unless of course the CD itself starts to break down over time. I know LEDs in flashlights are a relatively new technology, but I wonder how the dome bonding agents will hold up over time.
Any comments and/or experiences appreciated.
