B
bansuri
- Joined
- Mar 28, 2009
- Messages
- 885
There have been issues with the analog interface. The (+) end of the battery is faced with a foam rubber standoff to prevent the light from turning on, when you screw the head in and the battery overcomes the standoff it makes contact with a spring which initiates level 1. If you screw in some more, (amounts vary), it then causes the spring to make contact with a small solder blob on the PCB which then initiates level 2.
The distance between level 1 and 2 varies greatly and there have been other issues.
I did a big fix on my EZAA which entailed polishing the (-) end inside the tube which was grinding away at my batteries.
I removed the tiny spring on the PCB and reduced it's height and built up the solder blob, re-attached the spring which made it so there's a 1/2 turn between levels. Previously it was about 7/8 turn.
I also replace the foam standoff with a thicker version so the head isn't dangerously loose when in the 'off' position. Nope, that was the EZ123. sorry.
Now it's a nice little light . From the looks of it there will be no modding required with the Quark MiNi AA.
