Sold/Expired F/S mint ARC LS, offer withdrawn...
cy
USA
F/S mint ARC LS mod. 3watt UX1J, SO17, mineral lens. modded by CY from a new ARC LSH proto body. board has been boosted to 750 milliamps. UX1J emitter is attached with AA grease, allowing reuse of luxeon. no loctite is used to allow access.
offer withdrawn...
Runs great with R123 li-ion and std CR123.
Beam is bright and white!! Simply amazing performance!! First to post "I'll take it" without change gets it. Please PM for PP info.
Re: F/S mint ARC LSH-U proto WX1S, SO17
I'm confused. Does it have the U-bin 3 watt or a W-bin 5 watt?
It has the U-bin 3watt, corrected. apologies for the typo...
By proto, you mean its one of your prototypes?
As in, you wanted to see how a U bin would do in it? /ubbthreads/images/graemlins/thinking.gif
note ARC LSH body in picture has more knurling than std LSH body. ARC proto body has no markings...
an absolutely beautiful light!!!
Hey Cy:
Looks beautiful. How long is the runtime? And do you know the lux output or can you compare the output to something familiar, like the VIP or Lionheart or L4 or L6.
Thanks, Josey
This setup is made for running bright with 1x R123 li-ion or std CR123.
draws 781 millimps from R123 650 mah li-ion
offer withdrawn...
