locea
I need money,so I have to let my baby to new house
All is never used except Aleph 1-Seoul
1."The mouse" bought from EricMack
http://www.candlepowerforums.com/vb/showthread.php?t=188848
Asking $480 not including shipping and please add 4% for cover paypal fees
Some Specs:
300 lumens max output, 4 brightness levels, runs on 1xRCR123 LiON rechargeable at max for perhaps 45 minutes, min output of perhaps 2-3 lumens for 225 hours, full regulation for most of the runtime with approximate 95% average efficiency, several hours of low-brightness emergency light at tail end of runtime.
Can run on 1x123 primary cell with all brightness levels still available, but scaled proportionally less bright and longer-running... this would be a good option for power outage or other emergency use.
Acorn1.0 driver, basically a souped-up version of the driver developed for the Gotham.
Flushmounted tactical twisty switch heavily modified from the innards of a stock SureFire tactical twisty for smooth, light action.
Krytox and Nanolubricated threads fore and aft.
Flushmounted 'skyscraper-style' window with structural support from the backside, no visible retaining ring, reflectors moved as far forward as possible to eliminate bezel ring and head sidewall interference with the beam.
McR16ms reflectors, built to order by McGizmo for use with Seoul SSCP4 emitters, providing good throw from reflectors in this size category, while also delivering gradual intensity falloff from hotspot through outer sidespill for excellent field of view.
High density silicone foam in sidewalls to pad reflectors against lateral shock. High density silicone black matting with carbon fiber texture for aesthetics and circuit trace protection.
Dual-AR coated ultra-clear lens.
Shockmounted e-can in base of head for fit and shock resistance. All components in the head designed to be removable with no damage, glue residue, etc., should the owner ever wish to revert the head to more conventional single-reflector duty.
2.Aluminum S27 PD bought from ChocolateLab33
http://www.candlepowerforums.com/vb/showthread.php?t=188364
Asking $420 not including shipping and please add 4% for cover paypal fees!!!
The body and clip are fresh from modmags exotic coating GB. The body matches the head a lot better than the original slate coating it had and the Ti clip has been polished and coated with AlTiN. The piston has been milled to house one of B@rts 1.5x5mm trit vials(not included). The piston and head to body o-rings are new and freshly lubed giving this light buttery smooth piston and twisty action.
4.Aleph 1
Asking $250 not including shipping and please add 4% for cover paypal fees
PM me for get information.
Detail see pics.
Thanks.
Zhang.
Some Specs:
4.Aleph 1
Detail see pics.
Thanks.
Zhang.
