fan question
star882
C:\\Program Files\\CPF
I found a fan with 3 wires(red,black,white).
The back says 12v 0.15a.
Most of the 12vdc fans have 2 wires.
Is the third wire just to make the repairman think the fan is nonstandard?
Is it a 3 phase fan?
The 3rd wire is either a tach. pulse output for speed monitoring or a locked rotor indication.
"How do I connect it?"
You've indicated in other threads that you are somewhat of an electronics guru, i'm sure you can figure it out.
You connect it to a tach pulse counter or a locked rotor alarm circuit.
Almost every modern motherboard has connections for 3 wire fans.
The red wire is probably the +ve supply. black is ground and white, as i've said, is either a tach pulse or a locked rotor indicator.
correct- now try slowing down the fan (like by putting it flat on the desk) and the pulses will slow down, too.
Depending on the fan, it will pulse a certain number of times per rotation, allowing a monotoring program to track it, and do things like- Sound an alarm; shut down the system; Speed up all the other fans; Log it to a file; or some combination of the above.
