EatSleepRunBike
The Shark converter found at the Shoppe says that the input voltage should not start below 1/2 the output voltage/Vf for proper regulation, and should not fall below 1/3 of the output. Is the same case for the Fatman at Taskled.com, or is the Fatman more efficient than the Shark at lower input voltages?
