Wurkkos
Favorite Incan and led light
InvisibleFrodo
Well-known member
+1 on the K2 LFPs being super flat on the charge curve. They’re also very robust and can take abusive charge/discharge cycles. A charger that takes them up to 4.2 volts is technically overcharging them, and it’s like they just don’t care.
fivemega
Well-known member
California
vicv
Well-known member
Southern Ontario
Interesting that they put a buck/boost driver in it. Since it is a two primary cell light there's no need to have a boost circuit. That is excellent though
Olumin
Well-known member
"...that famous Texas part of Hamburg"
https://www.candlepowerforums.com/v...-By-FIVEMEGA&p=4286960&viewfull=1#post4286960
This is tail current of single mode Fury with different batteries or voltage.
As you see, lower voltage takes higher current as far as regulator can componsate total power (Voltage x Ampere) to LED
When power is within the range, regulation is acceptable and good.
Thanks very much for that info. I had noticed that indeed the brightness is the same whether I use CR123 or 16650, but its great to know that it stays in regulation regardless. Makes me appreciate the Fury even more.
UFO
Well-known member
Incan: Streamlight Scorpion
LED: Streamlight Stinger: Standard/HL/HPL
konifans
Well-known member
My favorite incans are mostly Kel-Lite and Maglite... if I have to choose one only that will be the little Kel-Lite 2C.
As for LED light... no I do not like LED...
bykfixer
Well-known member
1/2 mile past Yonder
In the vein of post 26 I can honestly say 2 favorites, one being incan and the other LED would be the 2C Kel-Lite.
Left with a Maglite PR xenon
Right Kel-Lite LED drop in prototype #11 of 14
325addict
Well-known member
The Netherlands, Amstelveen
My favorite incan light must be the FiveMega "Megalennium" 3S 18650. Add a standard SF M6 head, a WA1166 bulb if I remember correctly and of course a FM MN to bipin-adapter and you're ready to go!
My favorite LED flashlight? I don't have a favorite LED flashlight. I can only say the "least disastrous" LED flashlight, and that has to be the Nitecore SRT7, due to the easy-to-use selector ring AND the ability to go down VERY low, way under 1 Lumen. That way, even a LED-light doesn't blind you at night with full adapted night vision. On the other hand, it can be blindingly bright with just a twist of the wrist... continuously variable output is quite rare.
vicv
Well-known member
Southern Ontario
The mag lite XL 200 is like that. It can go quite low too. I'm not sure if it's sublumen though. My convoy s2+ will though so that light is basically relegated to night time in the house
